I need purchasing advice for Mig
Gaffer
H-M Lifetime Diamond Member
Sep 20, 2019
1,392
I'm a novice welder, at best, who simply loves futzing around with metal and projects. I want to add another Mig welder to my existing collection of welders because I need something with more power. The 220 VAC welder circuit in my garage is good for 90 AMPS. My current Mig is a Lincoln 125 Plus and works fine, but 1/8" is pushing it.
I have an opportunity to buy a used ESAB Migmaster 215 Pro for hopefully under $1,500, but let's call it $1,500. There are few reviews and very little about this machine's reliability on the web, but I believe it's a good machine. I've looked at inverters, but only the cheap-o's because they fit my budget. I'd rather have a better unit even if it's used. 110VAC and portability are not a concern. I'm not against cheap inverters. I picked up an HF Vulcan Pro Tig 165 for $170 several years ago, from HF, and it works great.
The ESAB retails for about $3,000, but I've seen it as low as $2,700. I haven't been able to find another name brand/reputable welder for sale in this price range near me. Thoughts?
I haven’t used one but ESAB has a good reputation.
No idea on the price but condition usually dictates that. Half on new for good used is a good starting point.
Esab is good stuff. If you can swing the 1500 bucks go for it.
I tend to agree with you NCjeeper. I can't get there to see it until the weekend, so if it was meant to be, it will be there. Thanks
30 years ago I used an ESAB MIG in my truck shop. It belonged to a farmer customer of my, but I had 3 phase and he didn't. It was fantastic! You could say WELD! and it would do it for you. Very high quality machine, no complaints. Used it for about 5 -6 years.
I currently have a Miller 211. About 5 years now in my home shop. Pretty much use .030 wire for everything. It will weld up to 3/8" and i use it mostly for 1/8 to 1/4" every couple days and it hasn't let me down. It sells for around $1400 new. I bought mine online cheaper then the local Miller dealer. You do need to use 220V. 110V won't cut it. It tends to run a tad hot for me, so I use it on the lower end of the recommended settings.
Pretty certain the Lincoln welder you have is the one I borrowed when starting back up years ago. Used it on 120V and I couldn't weld sheet metal together. Thought it was me, but it was the machine.
I’ve looked at the 211 too. I’m going to see what I can do with the ESAB first and go from there. I’m not in a rush and can be patient. Thanks for the input.
