- Jan 9, 2016
- 120
The thread title pretty much says it all! I need to pick up some boring bars for my 7x10 HF lathe, and I don't know what I should get. Aluminum will be the material I use most, followed up by plastics and brass. Steel will come into play somewhere down the road, but that likely won't be for a while.
I'm inclined to buy the inexpensive brazed carbide bars as trainers. I know the carbide will probably need to be sharpened, but I think I can handle that by hand with some diamond sharpening paddles. Any reason I should skip these and move on to one of the other choices? I would buy the HSS version, but my grinder / sharpening skills are way below adequate. They'll eventually get better, but I need to get rolling on this project sooner than that...
As far as the insert bars are concerned, I have no idea where to begin. Soooo many choices for both insert and tool, so many material possibilities, etc. I'm quite lost at this point, and am not sure if I should go this route or not (following the "buy once, cry once" method).
If it matters, I'm still using the stock tool post at this point. A QCTP setup is in my future, but not for a while yet.
Thanks!
Thanks!
