- Nov 14, 2016
- 3,291
I gather I'm not all that unusual in having all these tools but often lacking engaging projects...
A co-worker has a favorite key lanyard but the bit that holds the keys broke and without thinking she tossed the hook part. I looked at it and immediately thought, I know a guy with a bunch of tools that could fix that.
For those with a short attention span I'll put the completed project at the top.
I bought a zinc plated steel snap clip (not sure the technical name, but the silver thingy) and made up a two part brass thingy to attach it to the lanyard.
and the completed project, I added a drop of thread lock to the screw so the whole thing can swivel, but it shouldn't unscrew.
Kind of a simple thing, but it was kind of fun as I got to use a bunch of my toys. The first attempt was done without having the lanyard on hand and it didn't work out. On the second try she gave me the lanyard so I'd have it available to test fit. photos jump around a bit as some were from the first try, some from the second, so if you see some irregularities (like drilling a milled part that already had a hole while milling..) that is probably why. The small screw part was threaded with a die, but apparently I didn't take a picture of it.
Made with my Sherline lathe and mill and I got to use a 3 jaw chuck, ER16 and ER32 collet chucks, drills, tap, die, tail stock die holder, radius turner, and ER32 collet block. About 3 hours, $3000 of machines and tooling, and a couple pieces of left over brass to fix a $10 key lanyard.
