I know that getting a smooth final cut/finish cut is hard.
jbmauser
Apr 1, 2011
67
I know it is tool shape and carriage speed (i think). I can't seem to figure out a tool profile to get a smooth finish.
What's the nose radius on the tool you're working with?
Do you have enough radius on your tool tip?
Hey JB, maybe show us your tool? I bet the guys can get your sorted quickly.
Thanks all. I spent last night viewing videos on youtube and realize my radius is probably at fault. I need to grind a new tool this morning and apply what I learned and also apply a solvent. I may be back..... thanks again.
I agree with all the suggestions above, but i've had good luck with a fast feed rate, this requires lots of power from the lathe and good size tool but. I've gotten reflective surface finish with 400rpm and a fast feed but my lathe has 13,5 hp motor, you can try this metod and see if it works for you.
I find cast iron likes a high feed rate.
(13.5hp is a beast of a motor btw) ;)
