In what has become my day job, making balsa propellers, I've encountered a problem. The machine seen below, consists of a vertical spindle with a sanding drum on the bottom and a pulley/belt drive on top, a motor on the left which moves the spindle down to operation position or up out of position and a motor on the right which oscilates the spindle vertically about 3/8" maybe twice a second.
The motor on the right, osculation, stopped several months ago and I found a wire that had stopped conducting electricity. I replaced that wire and it continued to operate until today.
I've checked there's 110 (more like 122 at all connections, from the switch that controls it to the can on the motor. See Below.
I wish to know if this device can fail, how do I determine if it has?, and what is it called, (is this a capacitor?) and what to do to fix it. I haven't checked if it is grounded to the motor, should it be, or not?
And of course, if it hasn't failed, (proves out good) where do I look to get it to work again?
