A friend owns a sheet metal shop and is constantly breaking nibbler bits. They aren't cheap and he goes through thousands of dollars each year. I promptly put my foot in my mouth. "I could make those bits for half that price." Suddenly, I have a new project.
This is a no stress, once a year, low volume task. I have equipment to manufacture the bits except for one item... a tool grinder. The first production run will pay for that. I'm looking for suggestions on machining and sharpening the bits. The best way to learn to swim is by getting in over your head. So, please feel free to tell me I'm ignorant. I probably am.
The bits are M2 HSS hardened to RC62. Cheaper versions are A2 steel and don't last. The bits are 1 3/4" long. Photos are posted. The raw material is 5/16" diameter M2 round stock (annealed). I plan to manually mill one bit at a time. I did say low volume production didn't I?
The holding fixture is two custom, 6" long V blocks which are bolted together, clamping the stock between them. The fixture is rectangular and held by the mill vise. That allows me to accurately roll the fixture and stock in 90 degree increments. The fixture is made, but not tested. About 2 1/2" of working stock will stick out of the fixture. I'm hoping the short length provides enough stiffness for milling. I'll modify the fixture to provide backing / support if needed. A few swipes with an end mill on the top, sides and bottom and I should be golden. I'm not sure if climb or conventional milling will be more appropriate for the side cuts. Climb milling produces more side pressure. Given the dangling nature of the piece, it may wiggle. What is you guys' experience with supporting and milling small diameter round stock?
The set screw hole is made with a combo drill bit. No sweat. Cut the bit to length (lathe or bandsaw), deburr, and it's ready for the muffle furnace.
M2 has to be hardened in an oxygen free environment. At high temperatures, oxygen bonds with the carbon in the steel making CO2 or CO. It sucks the carbon out of the steel. To prevent that, wrap the steel in stainless steel foil, double the seams and hammer them flat. Some people leave a piece of paper inside to suck up the last bit of oxygen. Bake the cookies.
Now I'm stuck. The hardened bits will need sharpened (flat ground). I'm considering buying a tool grinder. I've managed without one, but this is an opportunity to expand the tool collection. Enco has one for $250 (891-8106), Harbor Freight for $189 (46727). The HF will need reworked. Not sure about the Enco. Both are cheaply made. Does anyone have a better suggestion? Will the stock wheels suffice for grinding M2 at RC62 hardness? I'm not sure what wheels are on them.
This is not a big or sexy project, but putting money in my pocket does sound like fun. Plus I gain a grinder and a little machine time. Am I on the right track with all of this?
