- Jul 26, 2014
- 93
Hello All;
I have a 7" x 12" Mini lathe and have been having an issue with my 3-Jaw chuck not holding the work well.
The lathe came with a small chuck wrench which I use however when doing projects when working with steel the part which is chucked often rotates making an awful mess of the finished surface.
I have tried tightening up the chuck with as much force as I am able to deliver but still have this issue.
Should I make up a new chuck wrench which has longer arms to allow me to put much greater pressure on the work piece? Or is there an issue with the chuck?
Thank you!
Thank you!
