I Hate Cleaning Chips Out Of T-Slots
Mini Cooper S
H-M Supporter - Silver Member
Aug 1, 2019
361
I know that others have made table covers before, this is just my take on it based on materials on hand. I have a 9 1/4" x 12 ft. length of .166" aluminum left over from when we had out manufacturing business, so I decided to put it to use. Made keys that fit into the T-slots to keep the covers from sliding around, yet easy to remove. I like aluminum because it won't absorb moisture and cause the tables to rust.
For the CNC.
For the manual mill. Note the extra cover to keep chips out from behind the DRO scale.
Keys to keep in place.
I made a couple of covers from hardboard, imbedded button magnets in bottom, painted, and put an raised edge around 3 sides to keep stuff from rolling off. No pics, my shop is still under winter wraps, so everything is coved in plastic
I usually choose to work with steel so that I can use a magnet for cleanup.
How do you get thru the winter?
I'd be jonesing real bad.......
-brino
Not much I can do, my shop ( garage is all block const.) It's not insulated, that would cost a fortune. About another month when the temps come up I'll be out there. I spend the winter dreaming up projects, and attempting to draw them up with AutoCAD
....it would take me several months of daily use to even start getting comfortable with Fusion-360.
and YES I have tried all the online and youtube stuff, including Lars Christensen.
It just doesn't stick!
Most likely because I only have a few hours a week for it. By the time I try the next step I have lost any previous knowledge.
One more thing I'll have to put off 'til retirement.
-brino
As I said I'm attempting, to use AutoCAD it does have a steep learning curve.
I wasn't doing too bad last year just simple stuff, well just as you said I lost most of what I learned. I found some good tutorials I'll post the link when I find them.
