That is fantastic, I've used an Alaskan mill and thought that was pretty slick but you definitely have a big hand up on that.
Shawn
My Brother in 100 mile house has a home made alaskan mill (Chainsaw mill for those that don't know) and it cuts pretty fast, but when you do the math, which is how much for the Alaskan mill set up? and a chainsaw that costs around a thousand dollars. My few hours of work and 1200 bucks in materials and it will beat a chainsaw mill hands down, problem with milling lumber is moving the logs to the mill, or moving them around on the carrage bed, in which case the chainsaw mill has an advantage, that you can just cut your boards out in the bush and carry the lumber out.
The Alaskan mill also takes up less room for storage, but it also has a wider cut, meaning that you could actually maybe get another board out of a log with a bandsaw mill in comparison.
As for speed?
I have yet to see a chainsaw keep up!
It all depends on what or how much lumber you actually need.
It is actually pretty fun making lumber in your back yard, it also allows you to make boards that you will never find in a building supply store.
One of the biggest things that I found while figuring out what works and doesn't, is
make everything adjustable!
Another thing to consider is that a mill is like a transport truck with a heavy load, it isn't so much the speed of the band blade as the torque behind it, so in order to acheive torque, you need horsepower, and you won't do well with anything less than 13 to 15 horsepower unless your just cutting softwood that is small logs, say 12 inch diameter.
There is a ton of information on the net, the problem is, that what one person would consider good, another person would consider garbage.
