Better late than never I guess but 30 years after the fact I finally got a chance to use my high school trigonometry. Just when I was beginning to think it was only good for impressing the girls at Hooters.
I was working on the layout for cutting out the dovetails for an infill plane. I took two scraps of roughly the same length. The thickness was off but that's not a dimension I was worried about for now. I used a carbide dovetail router bit to cut the tails in the side - easy as pie (it's the black piece in the picture). Then I had to cut the pins in what would be the bottom piece of the plane. That involves clamping the piece upright in the vise, turning it 14 degrees (to match the router bit) and routing out one edge of the slots with a regular end mill, and then turning the entire contraption 14 degrees in the other direction to get the other edge. Since each tail was 1.25" apart I thought it would be easy with the DRO to just crank one out, shift 1.25 and do another, shift 1.25 and so on. Well I did that and when I was done nothing fit - a drunken monkey might as well have milled out the slots using a wooden ruler for measuring.
I burned a few brain cells before I figured out that with the piece held 14 degrees off the X-axis, moving the X-axis 1.25" wasn't moving the cutting point on the workpiece 1.25".
I went in and drew a picture and the triangle jumped out at me. I looked up the cosine for 14 degrees (.9703) and figured for the question mark. Turns out I should have been moving it just 1.2128. I tried it with another piece of metal and perfect fit. For the real deal the sides will be peened (peaned? Piened? ) to the bottom so I'll move a skosh more to give it room.
