- Jan 6, 2017
- 1,248
I wanted it to be as low profile as possible,
so I decided to cut the 6" (6.5" actual travel), down to 5.35" of actual travel.
I didn't want to pay 300$ for the Motutoyo scale and risk destroying it when I cut it down. Since I kept reading that on the Shars and Igaging readouts, the display lags, (is slow to respond to quill movement), and eats batteries like crazy, I took a chance and ordered a M-Sure display from the UK, for 50$. It responds quickly, with no noticable lag. We shall see how it does with battery life.
My quill has about 5.1" of travel, so, the cut down scale gives me 1/8" of clearance both top and bottom of the range of motion.
That also got the scale overall length down to 8.625", so the scale only protrudes 1/8" above and below the head castings where the brackets attach.
I milled angles on the brackets to match the angles of the head casting. So overall, the brackets extend .2" above and below the mounting bosses the attach to.
It was just -mocked up- in this pic. When it's finished it should stop 1/8" short of the brackets in the fully up/down positions.
After getting it all put together and making sure it works, I took it apart and cerakoted the brackets. Going with "midnight bronze". A mix of 75% burnt bronze, and 25% graphite black.
It's in the cerakote oven baking at the moment. I'll post more pics whet it's done, in 2 hours.
