- Oct 16, 2019
- 29
I can grab my cross slide and push/pull it and the DRO shows it moves around .120
I have a PM1127 lathe, and if I have to turn something down, I gotta grab the cross slide and pull it back because if I push it to the workpiece, it gets pushed back a little bit. If I pull back on the cross slide, the Y axis stays the same when I'm turning. If I don't, the tool pressure pushes the cross slide back and I know this because the DRO changes. Is it the gib that I gotta tighten or is it the backlash nut I gotta tighten a bit?
