After adjusting speed (up and down), angle of cut (narrow to wide), I can't figure out what in the world is going on here. The warbly look is driving me crazy to solve. Is it the carbide inserts?
Thanks...
Maybe the tool is a tad too low, the feed is too aggressive, and the tip is catching and snapping back up, causing inconsistent depth-of-cut. Maybe chatter is being introduced by something on the compound not being strictly locked down. Maybe the work is hardened. You may want to try a HSS tool and dress it very sharp with some india stones. May want to try some lubricant. Reduce the speed, increase the feed. Seems like you've got enough feed though.
I have infinit control over speed, which is tied to feed, and it had no effect. Further, I used lube, no difference. The piece is 8 inches long with a great live center. I am wondering if I may need more support on the work piece, or it may be the carbide bits. Very strange. It is 6061 aluminum that I've used on my CNC mill with no problems. I am perplexed.
Hmm. Maybe the surface is/was oxidized and the depth of cut was insufficient to prevent galling. Maybe now you've broken through the surface it'll smooth out. Maybe a sharper hook angle is necessary if you can manage it with the tooling you have. Really sharp HSS should do the trick or chuck up a cheap steel bolt and see what the carbide does with it. I'm curious to know how it is resolved.
The 618 really isn't heavy enough for carbide. Try HSS and you'll see a much better finish. If you want to stay with inserts try AR Warner - they make HSS inserts.
Chrispy
