- Dec 12, 2021
- 84
I acquired a hydraulic ram about 8 feet length and 2.6 inches diameter. Is it useful as stock?
More details: Neither a file nor a hacksaw will bite into the polished surface. But grind off the outer layer and it can be worked with a file and a saw. I expected it to machine too, but that was a disaster. My lathe is a LMS 5100 with high torque motor. I cut off about 6", and center drilled it so that the stock was supported by a live center. I used carbide insert tool, but that failed until I used carbide tool with 0.125" radius and positioned the tip perpendicular to the stock. I could only cut about 3 mills without stalling the lathe and the insert produced a stringy chip, often with sparks or arc. It was hot.
Is the lathe too small for this job? Would HHS cut this material better? Would annealing help? Finally, will an end mill cut it on a mill?
I could just try all this myself, but I've already shredded my drive belt. More to the point, there may be ways to work this material that I have not thought of or know about.
Anyway, this is my second post. Any thoughts would be appreciated.
Spajo
Spajo
