- Jun 8, 2014
- 99
Does anyone know of a source for the hydraulic couplers used by Harbor Freight on their 10 ton and 4 ton hydraulic ram kits? As you can see from the photo they resemble Enerpac C604 fittings but are smaller. The male thread is 20.4mm OD and 1.25mm pitch. The cylindrical nose is 9.98mm OD.
I have recently picked up a couple of short (3") cylinders that I would like to use with my current 10 ton kit. I need a couple of female fittings (mates for the male fitting shown in the photo) for them and I also scored an Enerpac hand pump that has no coupler at the end of the hose (just 1/4 NPT) so I could use a male coupler to use it with the rest of my kit. If I can find them cheap enough I may build a manifold so that I can use both cylinders in tandem with one pump.
They are not available from Harbor Freight and my Google-fu has failed me.
