- Jul 29, 2015
- 93
The 90 volt DC motor on my HVL-H lathe had a bad cord that was cut thru partially from someone in it's past life. One of the wires finally came apart apparently and was arcing and smoking a wee bit. Unfortunately where it was cut is right next to the cord connector going into the motor. The Hardinge manual shows how to take the motor and drive assembly off the machine, but does not explain removing just the motor itself. The motor is a Bodine field wound magnet (?) type. I think I have to remove the brushes before pulling the two parts of the motor housing apart? Anyone have experience with this type motor?
