- Mar 25, 2020
- 108
What are you using to face your HSS cutters and how are you inspecting them before or between uses?
I am thinking to use a standard 6 or 8" bench grinder with coarse grit around 60 or 80 and fine grit as close to 240 as available as the first two steps.
Then follow if I can with a low speed grinder with finer white wheels. (Looking for recommendations)
Finally lapping with an Eze-lap diamond hand lapper or with a whetstone in the 2,000 to 10,000 grit range.
Inspecting initially by naked eye (everyday eyeglasses in place), then later with a 10X loupe: https://www.amazon.com/gp/product/B000CAHCQS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
- Who is using anything stronger than 10x optical to inspect tooling or products? What are you using?
- Who is re-sharpening HSS between uses or before it manifests edge degradation?
- How are you shaping and sharpening your tools?
- Where are you getting your better quality grinding implements.
- What are you using to hold HSS blanks in place position and orientation during grinding?
