- Mar 29, 2017
- 746
I have neither the room, or the dough, for a dedicated grinder. I do, however, have the 5C collet block set, some angle blocks, and a 3 inch wide, 1 inch thick, 14 inch long piece of 6061.
My idea is this- mill a pocket in the aluminium to accept the square collet block. The floor of the pocket at 12 degrees in the long way, flat side to side. Use a 12 degree angle for back rake, and end relief. Use the angle blocks to set side relief, and side rake.
Also to adjust back rake as experience dictates.
This setup clamped to the mill table, swinging a CBN wheel on an arbor.
This will be a bit of a pain to setup and use, I know. However, it would make for accurate, repeatable edge angle geometry.
I aim to give my floppy old Atlas/Craftsman lathe all the help I can. The ability to ACCURATELY grind tooling, to assess performance of the grind, and to minimize chatter is my goal.
Got an easier way? Lay it on me!
