Hss Boring Bar Bit Help
U
umahunter
Forum Guest
Register Today
When using a boring bar with a hss bit do you use a left or right hand bit ???
Sorry found the answer it's lh I had asked once before but couldn't find with the forum search . found it with the almighty google
Boring and threading are sometimes done by mounting a RT hand tool upside down, extended away from the operator.
This can make the machining operation more visable.
I loose threads all the time. There must be a way to peg them so we can find em again.
I tried to look up threads started by me like on other forums but couldn't figure out how then I just searched my name still no luck so I did my question and screen name on Google and success
