If the rip saw cavities are ground flat, they must be reground to the correct clearance angle for a proper cut.
To restore the relief, you can use a bench grinder or a tool with a diamond disc and a cut-off his grinder. After setting the angle of the relief correctly, the relief must be carefully put back into the saw. Take your time and fine-tune the angle until you get the result you want.
If you are unsure if you can sharpen the relief yourself, you should take your saw to a professional tool sharpening service. They have the equipment and expertise to regrind reliefs and restore saw cutting performance.
