So Ive been doing a repetitive job that requires switching between live center and drill chucks. (I dont have a turret attachment but def see why those were made). My procedure is basically wipe the shank and internal tapers clean then carefully tap using a rubber mallet or brass bar. Is this okay? I feel like the frequent banging is not doing the screw/nut assembly any good. Problem is if I only give it a quick shove by hand sometimes I end up with drill pulling the chuck out of the taper. Anybody know the "correct" procedure? Puttin it out there to get some thoughts on the subject. Thanks.
