The project to to re position two mounting arms on a telescope. The arms are cast aluminum. They have been machined to have 2 new bolt holes each for attaching to a cast aluminum base. The base is a 10 inch diameter cast aluminum cylinder about 4 inches long. The walls are about 1/4 inch thick. One end is solid. The question is how to accurately mark, drill, and tap mounting holes on the sides of the base.
The base has an alignment screw on the bottom, this will be used as the starting point for the subsequent measurements. I have a marble setup flat surface plate about 12 x 18 inches, 2 v blocks, a machinist square, calipers, and a dial indicator.
I believe the first step is the identify the points on the cylinder 90 degrees on each side measured from the alignment screw. The first question is how to measure and mark points on opposite sides of a 10 diameter cylinder and 90 degrees from a base mark.
The second step is to mark lines along the cylinder axis for the subsequent measurement and marking of the actual mounting holes. This can be done by placing the end of the cylinder on the v blocks on the set up flat so the sides are vertical. The location of the lines can be located with the machinist square. The mounting hole positions can be measured with the calipers.
This is all dependent on the two initial marks on opposite sides of a 10 cylinder and aligned 90 degrees from a base mark. I am stumped on how to do this. I hope this is clear, if it is not I will answer questions. Thanks Dan.
