Hello; I recently inherited this little Craftsman 109. Took the headstock apart, it has this planetary gear arrangement. In the pic, you can see some spalling on the inside - those dark spots - where the metal seems to have flaked out. Little bits of metal were all in the gear teeth. If this ran at all, I'm sure it made a crazy racket. The gears themselves look OK, and after cleaning they turn freely. So the question is what to do now... I was thinking of skim coating the inside of that housing with JB Weld. Or cut a disc of sheet metal and JB Weld it to the surface. Or am I overthinking it? Anyone seen this before? Thanks for reading...
