- Mar 22, 2014
- 870
I had to remove the 3/4 inch countershaft on my Craftsman lathe. This turned out to be no easy job.
I now have a pulley with a scored bore. I also have scored brass bushings on the countershaft support bracket. This happened as I pressed the shaft out of the pulley and bushings. The shaft had a lump from the set screws that held on the pulley and collar.
How can I clean up the pulley bore and bushings? Do 3/4 inch hones exist? Should I use a 3/4 inch reamer? Should I try emery paper wrapped on a wooden dowel?
