View attachment 226212View attachment 226212 OK, just joined so here is my first hopefully not to dumb question, what tool o do I use to remove this shell mill cutter for this R8 arbor?
Without the proper wrench, I would just take some flat stock as thick as the notches are wide and mill the center to fit in the notches. Then use an adjustable to turn it.
