Hi all! I've had my 12x36 General Machinery lathe since 1998 and it really hasn't needed much maintenance in all this time - one motor replacement and a switch. But now it is making coffee grinder sounds intermittently, and sometimes runs smoothly but a little while later, without having moved the work piece, there's suddenly runout. I suspect the spindle bearings, but I have been completely unable to remove the spindle in order to replace them.
What I've done is remove the cover over the left end of the main shaft, and then the tensioning nut that squeezes the left bearing. I removed any set screws I could see on the main shaft gears, as well as a key. I also removed the four bolts that hold a heavy duty frame around the spindle on the right. According to Youtube videos I've looked at, but which were not about my specific lathe, it would appear the main shaft is now ready to be pounded out from left to right. I tried that with a mallet and it moved a quarter inch. I tried with a heavier object and no luck. Ditto using a threaded rod. The thing just won't budge beyond a quarter inch and I'm afraid to escalate the force any further.
I'll attach the manual, which on page 18 has a drawing that shows the spindle and the gears on it.
Any pointers would be more than appreciated, I've been fighting this thing literally all day and am utterly stuck.
Thanks,
Alec
Thanks,
Alec
