If the scratches are deep,wet sand with 600 wet or dry,then 1200 if you have it. Simichrome polish,or most any silver polish will work well,especially if you really wear it out,so it becomes finer,as you polish. White automotive rubbing compound works fine,but don't use too much. You need to wear it out as you approach the clear finish you want. I polished many guitars with white auto compound.
