- Jun 8, 2016
- 640
I need some explanation please.
When setting the compound angle, which part of the scale do I read? Am I reading included angle? If it helps, I need to make some cones that are 60 degrees, as well as some that are 50 degrees.
I have a strange set up in that I have a Southbend compound mounted on a Logan 12" lathe. It's a double turret tool post cross slide with a compound mounted on top.
The compound has a scale around the front going from 90-0-90. When the compound is set so that it's movement is at 90 degrees to the ways, the scale lines up at the 90-0-90 marks. I'm trying to understand how to set it to cut accurate tapers with the compound.
I hope that makes sense. So for instance I will soon need to cut a 6 degree taper or 12 degree included. How do I read that on the scale?
