- Sep 22, 2010
- 7,222
http://www.neme-s.org/Shaper Books/...g Machine Parts Diagrams Series IJ and 2J.htm
"HOW TO QUICKLY TRAM A BRIDGEPORT MILL"
Extend the quill a little over 3" and lock it.
Place a 0-1" dial indicator so that it rests against the top of the quill.
Adjust the table to read a preload of 100 thousandths.
Crank the table down exactly 3" using the dial on the crank.
Multiply the reading times 3. (the indicator is now ~9" below the pivot point
of the head and you read 1/3 of that)
Adjust the head in the opposite direction the indicator moved by your figured
amount.
Check your work by doing it again, it should be dead on.
This works for both directions.
amount.
