I am looking to make a sine bar and the design I use requires a pin to be press-fitted onto a steel plate. The pin will not be subject to any stress but it need to stay in place securely. Assuming that I can drill a hole of diameter exactly the same as that of the pin, will it be possible to press the pin into the hole with a bench vice ? I believe the key is to ensure that the pin is perfectly perpendicular to the plate in the process and I cannot figure out a simple way to do it. Will appreciate some hints.
