- Jan 2, 2014
- 9,598
Hi all,
Over the years I have collected a number of brazed carbide lathe bits. Some were acquired in a "dull" state, some I have used enough(or incorrectly ) to dull.
So I started thinking about have a way to sharpen them. More out of interest and challenge than necessity.
I asked at my local new/used machinery place and ended up with a Norton diamond wheel for $25.
It is marked:
271880
ASD220-R75B56-1/16
MAX RPM 3025
Made in USA.
I did not measure it because I thought the dimensions would be in the part number. Now I know better.
I believe it is about 10 inch over-all diameter with a 3 inch hub hole and is 1/2 inch thick (wide).
From deciphering the part number based on the Norton abrasives e-catalog:
http://www.nortonindustrial.com/upl...talog-Superabrasives-8068-2014 Bookmarked.pdf
ASD is the abrasive type; 220 is the grit size; the rest has to do with grade, bonding, etc.; 1/16 inch abrasive depth.
Seeing the blue plastic wheel made me think it was a low-end wheel. I cannot find it in a Norton catalog, but the closest thing I've found is this very expensive wheel:
http://www.ebay.com.sg/itm/111635166608?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Any idea what type of machine this was made for?
Any suggestions for mounting? I am considering a two part aluminum hub to bolt onto/thru the plastic hub.
Can the bottom of the wheel run in a coolant? (ie. will is pick it up the coolant, or would I need a drip/spray application?)
Then I just need to figure out a speed reducer....
The plastic hub looks like it's been around a bit, but the diamond at the outside circumference looks unused.
Thanks for any help.
-brino
It is marked:
271880
ASD220-R75B56-1/16
MAX RPM 3025
Made in USA.
-brino
