I am machining aluminum disks to as tight a tolerance as I can. gt2 belts will be mounted inside out on the disks to be used as gear teeth.
My experience has shown that removing and remounting parts do not end up in the same place. I have heard the terms mandrel and arbor; I am not sure which is appropriate here. I would plan to make a mounting centering mechanism for my lathe. It has an MT3 center and a 3 jaw chuck.
What can I make to ensure increased accuracy when mounting these parts?
The blanks have nominal 1/2 inch center holes. They are between 3 and 6 inches in diameter and between 1/2 and 3/8 inch thick.
