The project is to mount a round 4 inch diameter disc square on a 1 inch diameter aluminum shaft. The disc is 3/8 of an inch thick. The disc should be centered and square. The outer inch of the disc will be used, however the center 2 inches may be part of the mounting. The shaft can extend through the disc.
I will be machining the disc I had thought about first boring a 1 inch hole. Second, machining a 'collar' about an inch long and 1 3/4 inches in diameter. The disc would be screwed to the collar. The collar would be screwed to the shaft.
The tolerances needed at the edge of the disc is +/- .002.
The primary tool available is a South Bend 9a in fair to better condition. Is this feasible? Is there a better way to do this?
