- Dec 12, 2021
- 84
I am asking whether the problem I describe here has a known solution. I clearly made a newbie mistake. I bought a 4" (100mm) rotary table with the intention of using my 4 inch 3-jaw and 4-jaw lathe chucks on the table. I did not think through how to mount the chucks. In my situation, the chuck covers the whole rotary table and that prohibits the use of T nuts, even with a plate adapter. My little rotary table has four mounting slots in a cross pattern.
I have searched for a solution on this site, but did not find it.
I have one possibility. The table is attached to its base with a screw from the bottom. I drilled the hole all the way through the table and then tapped the hole - I think it is 3/8". The hole comes through where the T-slots meet in the center of the table. I can bolt a plate to the chick and then open the jaws and bolt the adapter to the table. Clearly it could unscrew when rotated the wrong way.
I'm hoping there is a better solution.
Spajo
Spajo
