Another thing to watch out for if you are trying to use a better drill press for light milling is that although the better drill presses have 2MT or 3MT quills or spindles, few if any are hollow. So no draw bar. End mills pull when cutting to the side. If you aren't careful (and sometimes even if you are), the cutter pull will pull the MT cutter holder (or collet) out of the spindle taper and ruin the part (or worse). This happens even if the spindle is horizontal. I learned the hard way a long time ago not to use tang style cutter holders. I don't know why they are so relatively plentiful compared to drawbar style.
