I was watching a video on You-Tube by Claudio Grassi, in which he broached external/internal gears using a single-point gear cutter held in a tool holder.
I was wondering how he made the single-point cutter of the correct form to cut a gear tooth.
How about this. If you own/buy a involute gear cutter from, say, e-bay for $30 you can:
1. chuck it in an oven and anneal it.
2. Use your metal-cutting band saw to cut between each tooth through to the center .
3. This will yield a number of single-point gear cutter forms.
4. Back to the oven to harden the single-point cutters.
5. Design a tool holder (looks much like a boring bar) to hold the single-point cutter in the correct position.
Thus, you have your single-point broaching tool for cutting gear teeth.
What do you guys think about this approach?
