- Jan 20, 2015
- 93
Hi all,
My wife is an optometrist with a broken machine I need to fix. It's kinda like a microscope but for reading the prescription of a pair of eyeglasses. Like a microscope it has a pivot and a lock for adjusting the angle of the machine. The lock is busted due to some stripped threads on the brass rod. I will turn a new one out of steel but the I'm unsure of the best way to "hex" the end. To be specific the end that will fit inside the adjustment lever.
I could modify the lever and make everything round with a pin, but I thought this would be a good time to learn something new. Picks below.
Should I;
a) hand file it into a hex
b) set up my 3 in 1 to mill it (not sure of the best way to do that)
c) something different
Thanks all,
Carl
Should I;
Thanks all,
Carl
