The project is to make an adapter for a South Bend 9a to replace the compound feed with a milling attachment. The adapter is a cylinder about 1.4 inches in diameter and .8 inches long. There is a threaded hole in the center.
I started with a cylinder about .15 inches in diameter and 6 inches long. The cylinder was placed in a chuck and the end was centered with a dial indicator. A centering drill was used to make a alignment centering hole. From there a hss bit was used to turn the cylinder down from 1.5 to 1.4 inches. Then a hole was drilled in the center and then tapped.
A rod was placed in the center and centered in the chuck. The lathe was then turned on for observation. The part had a small wobble. I believe the cause was the drill hole was off center.
I believe the order above was wrong. The hole should be drilled first and then used for alignment. The sides should then be turned parallel to the hole.
Can anyone offer any advice on better way to create a hole parallel to the cylinder walls?
Thanks Dan
Thanks Dan
