The tram of my Emco FB2 mill is off along the Y axis by 0.05 mm over 150 mm. Not too bad really but as I have got some time now, I am thinking about doing something to correct it. My initial plan is to make a donut-shape shim to go into the tilting joint of the head. The shim will be about 1.5 mm thick, 110 mm in diameter. The critical dimension is the thickness difference across the shim - one side has to be be 0.04 mm thicker than the opposite side. What is the best way to make such a shim on a bench mill ? Will appreciate some ideas.
