The lathe is a a late 1945 South Bend 9a. It has an under motor mount. After much back and forth the lathe is installed on a new table. It is a tool room model with a free floating foot. In other words the bed is supported by 4 bolts to the casting near the head and the foot is supported by a floating cylinder that allows rotation about the bed longitudinal axis.
I purchased a master machinist level. It is accurate to .0002 inch per 10 inches. I have no practical way to test this the limits but I have been able to confirm is at least in the range of 10ths. I used the level on the saddle to test the saddle run out across the travel. It was actually very good for this a lathe this old, about 1 1/2 thousands end to end.
However I am unable to verify the horizontal flatness. The tail stock V is higher then the saddle V's. Simply setting the level on the saddle is a close approximation. Is this good enough? Is there a straight forward way to level this dimension? Given the nature of the three point support it should only be necessary to level this axis at the head. I there a good place to do this.
BTW: If anyone is interested this is a very interesting process. The level measurements respond to the weight of the saddle as it is moved end to end. There is some inherent flex in the mounting. I have not determined what is attributable to the bed versus the table.
