I like to use soft jaws for things like this. I do a lot a lot of discs in my shop. I'll machine the soft jaws to the diameter I need x 150 to 200 thousandth deep. Chuck up the piece and turn the OD down right to the jaws, then flip the part and do the remainder. Most of the time it's within a few thousandth s between one half and the other. Close enough, most of the time. You can do a similar thing with a jaw chuck and get it spot on. If you only have hard jaws, you have to space it off the back to get an even spacing. I've used parallels to get the spacing right. Just make sure you remove the parallels after you've clamped the part and spin it up.
