Hello guys;
I am rebuilding/restoring one of these old machines that was given to me by a friend and I ran into a problem that has me scratching my head as to a solution. Specifically, the bronze bushings inside the headstock cone pulley need to be replaced, and I am wondering how, after I have turned and installed new bushings into the cone pulley- how to hold it on the lathe spindle without damaging the pulley so as to finish machine the I.D. of the bushings to a running fit on the lathe's spindle? I am concerned about damage to the pulley because it is a Zamac casting and I am afraid that the chuck jaws will break or crush the pulley.
For machine tools I have a 9 X 20 Chinese lathe and a Taig mill to work with. I do not see the Taig as being much help here. I am considering using a chucking reamer to finish the I.D. of the pulley bushings (because the I.D. will be reduced slightly after pressing them into the pulley bore), but again- how to hold the pulley without damage to it? Any suggestions will be greatly appreciated.
