I am making a tool holder to hold 1/4" mills. This is my second try. On the 1st try I used a "1/4" reamer to make the hole for the milling bit. It ended up about .002" over size. The mill fits but with enough slop to produce a little runout.
I measured the reamer and sure enough it is a little oversize. The mill bits are .250" and not under or over size.
How do I make a perfect fit for the mill bit? Thanks; Don
