- Nov 24, 2013
- 268
Back in 2012 I bought a set of a Taig ER16 headstock along with a Sherline VS motor for a hobby project I was doing (the ER16 was fitted with a Sherline Pulley to match the Sherline motor pulley). Recently I bought a Taig Mini Lathe along with a 3 jaws chuck to start learning machining however this headstock is 3/4-16 (My mistake because I thought all Taig headstocks were ER16).
Since it’s easy to change the headstock along with the motor on a Taig Lathe I use the ER16 for milling and the 3/4-16 for turning by switching the ER16 pulley but then I have to re align the belt and this process became a pain so I bought a new Sherline headstock pulley part #43367. Now to another surprise the new pulley does not fit the 3/4-16 headstock and it looks like the ER16 Sherline pulley I had has been machined to fit.
The 3/4-16 shaft is 0.624” and the new pulley ID is 0.557” (the old pulley ID is 0.621”). My only option is to machine it myself since a local machine shop charges $75 just for the setup time! My machining skills are limited plus I don’t have any cutting tools neither I know what tool is required. I do have blanks of HSS 1/4" SQ stock which I can grind to what is needed if someone tells me what I need plus I have a set of 5 carbide cutting tools but I don’t think these are suitable for this job.
Any help is much appreciated
