- Jul 4, 2014
- 156
Guys
I am running into difficulty while trying to fit ball bearings. The bearing I have is about 5.5" in diameter.
I want the bearing to stay in its place once mounted on the shaft or bore but I always end up with it sliding away. As I get close to the desired diameter I reduce the cut to bare minimum steps. The shaft is still not accepting the bearing. So I take one more tiny cut using the same depth setting on my cross slide dial with a hope that it will give me the required diameter. Then I find the shaft is too loose for the bearing. I have the same exact experience in boring too. I dont know how else to do it. One moment it appears too tight and next time it is too loose. When am I going wrong? What is the right method to get it right? I do not want to use loctite to get over the loose sliding fit.
Thanks
Prasad
Thanks
Prasad
