JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
"how To" Files For Southbend Lathes
Status
Not open for further replies.
Site Founder
Administrator
-_How to Install and Level the lathe- Bulletin H3.pdf
3.6 MB
-_How_to_Grind_Lathe_Tool_Cutting_Bits_SB.pdf
1.9 MB
+How_to_Check_the_Felt_Oilers_in_SB_Spindles (1).pdf
177 KB
+How_to_Check_the_Felt_Oilers_in_SB_Spindles.pdf
177 KB
+SBL_Oiling_Guide.pdf
333.1 KB
+Where Do I Get the Felts For a Heavy 10 (1).pdf
110.1 KB
+Where Do I Get the Felts For a Heavy 10 (2).pdf
110.1 KB
+Where to Buy Lubricants for Your Lathe.pdf
184.3 KB
-How to Adjust Gibs on Compound and Cross-Slide.pdf
54.1 KB
-How to Adjust the Spindle on the Heavy 10.pdf
507.9 KB
-How to Adjust the Vertical Height on a Tool Bit (1).pdf
135.9 KB
-How to Adjust the Vertical Height on a Tool Bit.pdf
135.9 KB
-How to Anchor a Chuck on a Threaded Spindle.pdf
209.6 KB
-How to Assemble a 10L Apron-Part 1.pdf
63.8 KB
-How to Assemble a 10L Apron-Part 2.pdf
75.5 KB
-How to Assemble a 10L Apron-Part 3.pdf
66.2 KB
-How to Bevel Pipe on a Heavy 10.pdf
600.2 KB
-How to Check the Accuracy of a Starrett Model 98-6 Level.pdf
99.3 KB
-How to Disassemble a South Bend Lathe for Moving (1).pdf
614.1 KB
-How To Disassemble a South Bend Lathe for Moving.pdf
325.5 KB
-How to Disassemble and Assemble a Single Lever Gear Box IIb.pdf
4.9 MB
-How to Disassemble and Rebuild the Apron (1).pdf
1.5 MB
-How to Disassemble and Rebuild the Apron.pdf
1.5 MB
-How To Do The Serpentine Belt Conversion_2.pdf
144.8 KB
-How to Do the Serpentine Belt Gluing.pdf
248 KB
-How to Fix a Power Feed that Stops Working.pdf
300 KB
-How To Grind Lathe Tools compressed.pdf
2.2 MB
-How to Hook an Automation Direct VFD to SB Lathe.pdf
134.4 KB
-How to Improve the Feed on the 10L Taper Attachment (1).pdf
357.8 KB
-How to Improve the Feed on the 10L Taper Attachment.pdf
357.8 KB
-How to Install a Tachometer Setup.pdf
509.3 KB
-How to Install and Level the lathe- Bulletin H3.pdf
3.6 MB
-How to Maintain the Headstock Spindle Sleeve Bearings.pdf
698.9 KB
-How to Make a Chuck Adapter for a Buck Chuck.pdf
1.3 MB
-How to Make a Quick Release Hand Crank.pdf
253.7 KB
-How to Make a Screw Driven Spindle Gear Press.pdf
217.3 KB
-How to Make a Swinging Thread Tool.pdf
893.4 KB
-How to Make Cast Base Lathe Leg Adjusters.pdf
228.3 KB
-How to Make Gaskets Between the Lathe and Bench.pdf
298.8 KB
-How to Make Roller Bearing Steady Rest Fingers.pdf
309.7 KB
-How to Make Taper Attachment Parts.pdf
295.5 KB
-How to Make Two Tools to Remove Cross Feed Handles.pdf
259.9 KB
-How to Modify a 10L Cabinet to Add Slide-Out Shelves.pdf
334.7 KB
-How to Prevent a Chuck from Sticking.pdf
42.7 KB
-How to Refinish Your Lathe.pdf
230.7 KB
-How to Remove a Stuck Chuck- Alternate Method.pdf
165 KB
-How to Remove a Stuck Chuck.pdf
807.4 KB
-How to Remove Rust from a South Bend Lathe.pdf
666.4 KB
-How to Remove the Lead Screw.pdf
129.5 KB
-How to Remove the Lower Countershaft from the 10L (1).pdf
188.1 KB
-How to Remove the Lower Countershaft from the 10L.pdf
188.1 KB
-How to Remove the Spindle from the Heavy 10.pdf
38.8 KB
-How to Repair the Cross Slide Screw.pdf
287.4 KB
-How to Replace Sliding Gear Shaft- Single Lever QC Gearbox.pdf
74.9 KB
-How to Replace the Tube on a Handlever Collet Closer.pdf
1 MB
-How to Revive the 10L Crossfeed Taper Screw.pdf
442.4 KB
-How to Set Up the Teco JNEV-101-h1.pdf
125.1 KB
-How to Use a Thread_Dial_Indicator_on_the_Lathe.pdf
1.6 MB
-How to Use Rollie_s_Dad_s_Method to Level the Lathe.pdf
12.5 KB
-How to Wire a Capacitor Start Motor 1of 2.pdf
2.2 MB
-How to Wire a Capacitor Start Motor 2of 2.pdf
2.4 MB
-How to Wire Push Buttons to TECO EV VFD.pdf
454.4 KB
-How_to_Check_the_Felt_Oilers_in_SB_Spindles.pdf
177 KB
-How_to_Cut_Screw_Threads_SB.pdf
1.9 MB
-How_to_Do_the_Serpentine_Belt_Conversion.pdf
1.1 MB
-How_to_Fit_a_Taper_Attachment_to_the_Lathe.pdf
1.1 MB
-How_to_Grind_Lathe_Tool_Cutting_Bits_SB.pdf
1.9 MB
-How_to_Install_a_Serpentine_Belt.pdf
1.1 MB
-How_to_Keep_Your_Lathe_In_Trim.pdf
2.8 MB
-How_to_Maintain_the_Back_Gear_and_Eccentric_Shaft_Form2000.pdf
196.9 KB
-How_To_Make_a_Chuck_Backplate.pdf
779.2 KB
-How_to_Refurbish_a_10L_Index_Plate.pdf
113.9 KB
-How_to_Remedy_a_Sticky_Clutch_Form2003.pdf
333.6 KB
-How_to_Remove_Crossfeed_and_Compound_Handles.pdf
45.5 KB
-How_To_Remove_Spindle_Gears.pdf
292.1 KB
-How_to_Repair_a_Spindle_on_16_SB.pdf
281.4 KB
-How_to_Replace_Spindle_Fiber_Discs_With_Thrust_Bearings (1).pdf
365.2 KB
-How_to_Replace_Spindle_Fiber_Discs_With_Thrust_Bearings.pdf
365.1 KB
-How_To_Run_a_Lathe_1966_Pt1_PDF1.pdf
2.9 MB
-How_To_Run_a_Lathe_1966_Pt2_PDF2.pdf
3 MB
-How_To_Run_a_Lathe_1966_Pt3_PDF3.pdf
3.2 MB
-How_to_Run_a_Lathe_old.pdf
3.1 MB
-How_to_Use_a_Lathe_American_Machine_tools.pdf
1.5 MB
-How_to_Use_the_Threading_Dial_ATT-95.pdf
213.2 KB
3.6 MB
1.9 MB
177 KB
177 KB
333.1 KB
110.1 KB
110.1 KB
184.3 KB
H-1 Keeping Your Lathe Clean.pdf
1.4 MB
54.1 KB
507.9 KB
135.9 KB
135.9 KB
209.6 KB
63.8 KB
75.5 KB
66.2 KB
600.2 KB
99.3 KB
614.1 KB
325.5 KB
4.9 MB
1.5 MB
1.5 MB
144.8 KB
248 KB
300 KB
2.2 MB
134.4 KB
357.8 KB
357.8 KB
509.3 KB
3.6 MB
698.9 KB
1.3 MB
253.7 KB
217.3 KB
893.4 KB
228.3 KB
298.8 KB
309.7 KB
295.5 KB
259.9 KB
334.7 KB
42.7 KB
230.7 KB
165 KB
807.4 KB
666.4 KB
129.5 KB
188.1 KB
188.1 KB
38.8 KB
287.4 KB
74.9 KB
1 MB
442.4 KB
125.1 KB
1.6 MB
12.5 KB
2.2 MB
2.4 MB
454.4 KB
177 KB
1.9 MB
1.1 MB
1.1 MB
1.9 MB
1.1 MB
2.8 MB
196.9 KB
779.2 KB
113.9 KB
333.6 KB
45.5 KB
292.1 KB
281.4 KB
365.2 KB
365.1 KB
2.9 MB
3 MB
3.2 MB
3.1 MB
1.5 MB
213.2 KB
Status
