Stock is both too long for the bed and too wide for the spindle bore. What are some techniques to drill a fairly accurate hole in the end? Drill press is too short as well.[/QUOTE. Did you wonder what
Those stiff- joint calipers with the miss- matched ends were for ? Put your work on
something as flat as you can find, approximate a big pair of v- blocks,wood, a try-
square, wood chisel, etc. Mark the center with the calipers. Level the workpiece
With a real v- block shimmed up to the diameter of your drill (level everything),
Use a straight- edge to sight sideways.Get a good start and " balance" the drill.
A helper wih a good eye makes it easier..........BLJHB
