Dimensions are roughly 1.5" diameter, .5" thickness. The center hole is .25". The hole on top is for a set screw. The 2 rods sticking out are 3/16. Material is Aluminum.
Hi All,
I need to drill a .375" hole through the side of the cylinder. It needs to be offset from the center hole so there is no interference, but as close to the center as possible (see pic)
My initial thought is to mill a flat spot for measuring and a center punch, is there a better(easier) way? The most important thing is that I don't drill into the center hole.
I tried to place the hole in solidworks, but couldnt figure that out either..
Thanks!
Roger
Hi All,
Thanks!
Roger
