Guys I need to try and figure out how to lay out 8-8/32 holes to match the SB mill gear.The other 1/16 thick plate mounts to the gear to keep the timing belt from sliding down has broke into and the old holes in the plate is wore out and very loose even when the screws are tight.I can figure out how to cut it into a circle but I am at a lost how to lay out for 8 holes that needs to match the gear.I have painted the plate so that I can see and try to do a good layout.
For me this is not an easy project cause I am not good at laying out holes(any kind of math) to match and I know that it will be hard for me to comprehend the best and easies answer but I am going to try.If you know of any websites that explains or and links to Youtubes,etc please let me know
