Carbide inserts are coded in a letter-letter-letter-letter-number-number-number key. I am under the assumption that inserts are interchangable with tool holders. I have a set of TCMTNNN inserts and what I thought was a compatable holder. However the insert hole diameter are different. I have read the description of the index fields and I can's identify which field specifies hole diameter.
My question is if the standard descriptor is L1-L2-L3-L4-N1-N2-N3 which field specifies diameter?
Thank you, Dan
Thank you, Dan
